Doggerel
Mar 08, 2019Aspirant
ReadyCloud Desktop Client ERR_NETWORK ERR_CONNECT
I continue to have the same issues as this thread describes. I am running Windows 7 Professional and have all the current firmware and software updates. I installed the new software from the link p...
- Mar 10, 2019
Along with TLS 1.2 support on ReadyCloud Server, ReadyCloud Win client is upgraded to v.1.17 with TLS 1.2 support either. It’s found new version doesn’t work in old Windows version such as Window 7, the reason is TLS 1.1 and 1.2 are not supported on old Windows version.
Could you please try this ?
mkrt
Mar 10, 2019Star
i am having the same issue and after finding this thread i updated the readycloud app but the problem is not solved. also the newer version of the app seems to not be working correctly at all. i tried to reinstall app and restart pc several times but it doesn't help. i am using windows 7
