Doggerel
Mar 08, 2019Aspirant
ReadyCloud Desktop Client ERR_NETWORK ERR_CONNECT
I continue to have the same issues as this thread describes. I am running Windows 7 Professional and have all the current firmware and software updates. I installed the new software from the link p...
- Mar 10, 2019
Along with TLS 1.2 support on ReadyCloud Server, ReadyCloud Win client is upgraded to v.1.17 with TLS 1.2 support either. It’s found new version doesn’t work in old Windows version such as Window 7, the reason is TLS 1.1 and 1.2 are not supported on old Windows version.
Could you please try this ?
Icewaterhot
Mar 10, 2019NETGEAR Employee Retired
- Marc_VMar 12, 2019NETGEAR Employee Retired
Hi Doggerel
Can you try to disable your Antivirus program if you have any, uninstall the ReadyCloud app manually and make sure that the ReadyCloud folder is completely removed from the programs folder. After this, you can try to reinstall ReadyCloud Client v1.17.
Please let us know if this works.
Regards - mkrtMar 15, 2019Star
this worked for me - https://support.microsoft.com/en-us/help/3154518/support-for-tls-system-default-versions-included-in-the-net-framework
- IcewaterhotMar 17, 2019NETGEAR Employee Retired
mkrt Thank you for your feedback.
