Jmonteny
Jun 10, 2017Aspirant
ReadyCloud: Device is offline
Please help me! I have a normal acces via the admin page, but via the readyCloud still the message device is offline. The readyCloud in the settings is turned on. I am also facing problems with ...
- Jun 16, 2017
I updated it to 6.5.2 and I've just updated it to 6.7.2.
Updates should work the normal ways (local or remote update) going forward.
You should be able to join your NAS to ReadyCLOUD now. Please check this too when you get the chance.
Jun 12, 2017Guru - Experienced User
Jmonteny wrote:
The systems asked to reboot, I confirmed. After the reboot still firmware 6.2.0 is valid and again systems asks me to upgrade to versie 6.2.5.
So still no luck. What should I do now?
Let's give mdgm-ntgr a chance to chime in.
In the meantime, download the log zip file from the logs page in the web ui, and look at initrd.log. If there's an error in there, please post it here.
mdgm-ntgr
Jun 13, 2017NETGEAR Employee Retired
There was a known issue with firmware updates/OS Re-installs especially with the 6.2.5 firmware release: ReadyNAS OS 6: RN100/RN2120 cannot update due to invalid checksum
Please try the steps in that article. If it still doesn't work seeing you've just reset the system you could do another factory reset and try the steps in this article again.
- JmontenyJun 14, 2017Aspirant
Thanks mdgm, no luck. followed the procedure from the article, but didn't solve the problem.
