Jmonteny
Jun 10, 2017Aspirant
ReadyCloud: Device is offline
Please help me! I have a normal acces via the admin page, but via the readyCloud still the message device is offline. The readyCloud in the settings is turned on. I am also facing problems with ...
- Jun 16, 2017
I updated it to 6.5.2 and I've just updated it to 6.7.2.
Updates should work the normal ways (local or remote update) going forward.
You should be able to join your NAS to ReadyCLOUD now. Please check this too when you get the chance.
Jmonteny
Jun 14, 2017Aspirant
STephen, Thanks again for your help. Please find the requested log:
[2017/06/09 13:32:49] Factory default initiated by Frontview!
[2017/06/09 13:33:02] Defaulting to X-RAID2 mode, RAID level 1
[2017/06/09 13:33:39] Factory default initiated on ReadyNASOS 6.2.0 (ReadyNASOS).
[2017/06/09 14:03:55] Update image checksum mismatch (fdb42adc37bd0b6b90a04244c1606484/9d1941e23efc2d3aa935edf5e1bfcc37)!
[2017/06/09 14:08:00] Update image checksum mismatch (fdb42adc37bd0b6b90a04244c1606484/60164e0f087bce909f9ca0c2cb881359)!
[2017/06/09 14:12:27] Update image checksum mismatch (9c1369b18de3a518460b0b67ba46e547/85c00b3b299aa23e4b8d6df6ff4ede6f)!
[2017/06/12 11:17:11] Update image checksum mismatch (f56361e8889d56a1b15cac0749dc0ac4/fa6467e46653b3cd194dd38007c81660)!
[2017/06/12 11:35:36] Update image checksum mismatch (fdb42adc37bd0b6b90a04244c1606484/04d47f1759c37f89b90690f6ce80cb90)!
[2017/06/14 13:03:36] Update image checksum mismatch (9c1369b18de3a518460b0b67ba46e547/7ba0627aee97c56dea9d15870e7089ab)!
Jun 14, 2017Guru - Experienced User
You clearly do have the image checksum problem - if the procedure mdgm-ntgr posted doesn't work, then you'll need assistance from support.
- mdgm-ntgrJun 16, 2017NETGEAR Employee Retired
- JmontenyJun 16, 2017Aspirant
Thanks mdgm and stephen,
Everything solved. I could now online update firmware from 6.7.2. To 6.7.4.
And i have access again via readycloud.
Nice weekend.
