Jmonteny
Jun 10, 2017Aspirant
ReadyCloud: Device is offline
Please help me! I have a normal acces via the admin page, but via the readyCloud still the message device is offline. The readyCloud in the settings is turned on. I am also facing problems with ...
- Jun 15, 2017
I updated it to 6.5.2 and I've just updated it to 6.7.2.
Updates should work the normal ways (local or remote update) going forward.
You should be able to join your NAS to ReadyCLOUD now. Please check this too when you get the chance.
Jun 14, 2017Guru - Experienced User
You clearly do have the image checksum problem - if the procedure mdgm-ntgr posted doesn't work, then you'll need assistance from support.
mdgm-ntgr
Jun 15, 2017NETGEAR Employee Retired
