ryanrk
Aug 14, 2017Apprentice
ReadyCloud doesn't work with T-Mobile
I recently was unable to connect to my nas from readycloud on iPhone on the T-mobile network. I use to be able until recently. It was recently that it stopped working. I did a posting on T-mo...
JennC
Aug 18, 2017NETGEAR Employee Retired
Hello ryanrk,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
ryanrk
Aug 21, 2017Apprentice
So Tmobile replied saying that there network uses IPV6 exclusively and thinks that ReadyCloud app on IOS isn't IPV6 compatible. Is ReadyCloud app IPv6 compatible? Could this be the reason why it doenst work?
Here's the Tmobile thread. https://support.t-mobile.com/message/610990#610990
- mdgm-ntgrAug 22, 2017NETGEAR Employee Retired
That is the reason. ReadyCLOUD uses an IPv4 connection.
- ryanrkAug 22, 2017Apprentice
According to apple https://developer.apple.com/support/ipv6/. All apps need to support ipv6 only connections. Is this something that will be updated in the near future?
- JennCAug 23, 2017NETGEAR Employee Retired
- StephenBAug 23, 2017Guru - Experienced User
JennC wrote:
Perhaps you can post a suggestion at idea exchange board.
Just to clarify the suggestion: You need the VPN to run over an IPv6-only network. The VPN itself could still use IPv4 addresses.
