geekstar331
Dec 02, 2014Tutor
ReadyCloud Feedback
1) When setting up the ReadyNAS from the Cloud Tab of the Admin page (locally)... The first time you turn the ReadyCloud switch to ON, it asks you for a username and password. You should add some ve...
Nhellie
Dec 30, 2014Virtuoso
Maestro,
What FW version are you running on?
I haven't tried using a static IP on the NAS, but my suggestion is instead using static IP on the NAS try reserving an IP address on your router instead.
