geekstar331
Dec 02, 2014Tutor
ReadyCloud Feedback
1) When setting up the ReadyNAS from the Cloud Tab of the Admin page (locally)... The first time you turn the ReadyCloud switch to ON, it asks you for a username and password. You should add some ve...
Maestro11
Jan 01, 2015Aspirant
Nhellie,
Thanks, I am running 6.2 I have not updated to 6.2.2 since I read that some people were running into issues. However, I did just install a new Netgear wireless router since my old one was giving me issues and it did not support 1000BaseT connections. The old router did not support reserving IP so the only way to do port forwarding was to set the device to a static IP. The new one does support this so I will give it a try and see if that fixes offline issue as well as external VPN connection showing not connected.
