geekstar331
Dec 02, 2014Tutor
ReadyCloud Feedback
1) When setting up the ReadyNAS from the Cloud Tab of the Admin page (locally)... The first time you turn the ReadyCloud switch to ON, it asks you for a username and password. You should add some ve...
Maestro11
Jan 29, 2015Aspirant
Sorry for taking so long too get back top this topic I got busy with some other issues and now finally had time to do testing.
The issue with "Online (VPN Disconnected)" with the mac App appears to be a mac issue.
I have set up on a new netgear router with the NAS having a reserved IP address and port 6300 forward to that IP address and updated my NAS to 6.2.2. The Mac ReadyCloud App will connect to the NAS when I am within the same network, but I keep getting the "Online (VPN Disconnected)" message outside the network. I also test the Window's version of the app internal and external and it works fine and connects with no issues. The mac version takes a very long time to try to connect and them times out with the "Online (VPN Disconnected)" message. I am not sure what the issue is at this point.
Where do I report this issue with Netgear?
