geekstar331
Dec 02, 2014Tutor
ReadyCloud Feedback
1) When setting up the ReadyNAS from the Cloud Tab of the Admin page (locally)... The first time you turn the ReadyCloud switch to ON, it asks you for a username and password. You should add some ve...
_shaw
Feb 22, 2015Aspirant
I think there may be a problem with ReadyCloud if the NAS is switched from DHCP to static. My setup loses ReadyCloud when static picks it up again when using DHCP. In my case using IP4 but others have flagged the same with IP6.
If anyone else can replicate this it may be worth feeding back, it's not expected behaviour.
