geekstar331
Dec 02, 2014Tutor
ReadyCloud Feedback
1) When setting up the ReadyNAS from the Cloud Tab of the Admin page (locally)... The first time you turn the ReadyCloud switch to ON, it asks you for a username and password. You should add some ve...
rovingmedic
Feb 22, 2015Tutor
I had this same issue after a factory default. If I set up ReadyCloud while unit was still on DHCP (IP4), then it wouldn't find the NAS when I switched to a static IP (IP4). However, if I deleted the account, changed to static and then connected to ReadyCloud then everything worked as expected. Experienced this a couple of times as I did a number of factory resets in short succession while setting up my new RN316. I have no experience with IP6.
