uffgnu14's avatar
uffgnu14
Luminary
Jul 26, 2020
ReadyCloud for Windows/Android hidden shares, different behavior, RN422?
Hi
Accessing my RN422 over ReadyCloud works fine and all shares shown in the apps for both Windows and Android.
With RC for Android I can access all shares, including Hidden ones (SMB-settings under main administraton account).
With RC för Windows I can access all shares but the Hidden ones. In this situation the File Explorer is not opening.
How should it work? Am I missing something?
In both cases I´m using the same RC administrator account.
Also the same behavior on local and remote network.
ReadyNAS 422 with OS 6.10.3
Windows 10 Home (version 2004)
Android 9
ReadyCloud for Windows 1.20.1304.567 and 1.19.1301.569
ReadyCloud för Android 2.0.7
Best regards,
Ulf
  • Hi,
    My mistake, the Hidden-attribute was not the cause of the problem with RC for Windows,
    instead the Read/Write-attribute was not enabled for the RC-admin-account in SMB/Security.
    I suppose the allways full access for a RC-admin-account with RC for Android is by design.
    Best Regards,
    Ulf
1 Reply
  • Hi,
    Best Regards,
    Ulf
ProSupport for Business
