twopods
Oct 26, 2020Aspirant
ReadyCloud Hangs saying "Connecting" Then says "Offline"
As above really. I log in, then it says connecting for ages, then says "Offline" I know the server is online as I'm using my network drives. I'm throughly confused as it has worked well for so ...
- Oct 28, 2020
Hi
Thanks for your help.
Yes, I can log on to the main page and all is as it should be.
It now seems to working (for the moment at least ! ) :smileyembarrassed:
I'm starting to think it was a Windows 10 update bug
JohnCM_S
Oct 27, 2020NETGEAR Employee Retired
Hi twopods,
Are you able to access the NAS when you try it on the ReadyCLOUD web portal (readycloud.netgear.com)?
Did you encounter the same issue when you try it on another PC?
- twopodsOct 28, 2020Aspirant
Hi
