perrij3
Apr 17, 2017Guide
ReadyCloud Invite Link Not Working
We were recently were affected by the ReadyCloud issue where our ReadyNAS left the ReadyCloud system. Due to this, all our offsite users accounts were deleted. When I go to recreated them, they are...
- Apr 28, 2017
After Netgear support fixed another issue with the drive, this problem has gone away. I'm not sure how the 2 issues are related, but the issue that was fixed was the drive stopped working properly (was not able to access any shares) due to the antivirus program installed on the drive.
Details about that issue can be found here:
https://community.netgear.com/t5/Using-your-ReadyNAS/All-shares-disappeared-after-updating-to-Firmware-version-6-6-1/m-p/1271884Thank you to all those that made suggestions about how to resolve this issue.
JennC
Apr 24, 2017NETGEAR Employee Retired
Hello perrij3,
I need you to update this thread with the screenshots and what turned out to be the issue so I can check this others from Netgear.
The issue with SMB not enabling may need to be fixed from the back end.
perrij3
Apr 28, 2017Guide
