WildfireTech
Sep 17, 2018Guide
ReadyCLOUD iOS App Security Not Aligned with NAS
Howdy! I have a RN312 with a few shares but I CANNOT assign permissions to my admin login email; hence, I cannot access any shares remotely as the admin user.
Can someone PLEASE tell me what's wrong?
Hi WildfireTech,
Have you tried reinstalling the iOS App you have? What firmware is your ReadyNAS running?
Kindly update the firmware to the latest if not yet done then try to reinstall the App first then relogin to your ReadyCloud account
- Marc_VNETGEAR Employee Retired
Hi WildfireTech
ReadyCloud admin account should have access to shares by default. Have you set any permissions on your shares before this happened?
What error message are you getting? You may want to recheck the permissions.
Here are some articles
On ReadyCloud Portal, you can go to Manage tab and check on the Share permissions.
Hope this helps!
RegardsMarc,
Thanks for the response. The error I am getting through the ReadyCOULD iOS App is "Error 403 - Forbidden"
I just did some more testing, and I only get this error when I am mobile (i.e NOT on the home LAN/WAN network). When I am home I do not get this error. Does that indicate that the issue may be with the app itself, and not the permissions? Or is this expceted that the iOS app doesn't allow "remote access" to files through ReadyCLOUD?
Hi WildfireTech,
