AnthonyTran
Jan 14, 2022Aspirant
ReadyCloud is not running on HTTPS
This topic has been raised before - see https://community.netgear.com/t5/ReadyNAS-Cloud-Storage/Secure-connection-to-http-readycloud-netgear-com-HTTPS/td-p/1482577, but now is Jan 2022 and ReadyCloud...
AnthonyTran
Jan 16, 2022Aspirant
Do you have any kind of security design/drawing of how ReadyCloud operates to post for us to reference?
I assume by "operator" you mean for it to perform some sort of coordition. If that is the case then ...
1) Why shouldn't the "agent" in our browser talk with Netgear server "operator" through HTTPS by/through the Netgear server certificate?
2) Communication between the "agent" in our browser (or client in your words) can talk to the server (a.k.a. our NAS or cloud enabled Nighhawk router) by/through the server certificate itself - assuming it actually makes use of SSL.
3) If the Netgear server "operator" also needs to talk to the server (e.g. our NAS), it can do so by/through the server certificate.
Please refer to my attached drawing for what I try to explain here. Thanks.
Jan 16, 2022Guru - Experienced User
FYI - this is a user <-> user forum and neither Sandshark nor I work for Netgear. Netgear hasn't published the info you are requesting.
The most recent comment from Netgear that I've seen comes from JohnCM_S (who is no longer with Netgear). See post 2 here: https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/ReadyCloud-security-issues/td-p/1900486
- AnthonyTranJan 17, 2022Aspirant
Thanks guys but the specified old post didn't actually explain things any clearer as to why/how it could not work with HTTPS.
Too bad because ReadyCloud has potentials to be great.
