Brenakie772
Mar 21, 2017Tutor
ReadyCLOUD isn't Syncing
Hi, Read some related threads and couldn't find a solution. I have a PC directory on the readycloud and it's synced. I was off site and needed to do some work. I accessed the file (.PSD)...
- Mar 24, 2017
Do you see a green tick on share icon and "synchronized" status after sync is finished? Like
Where do you check your local PC folders?
YES!
Notice: When you stop a one-way sync job, the original local folder on your PC don't have any connect with nas. After you create a 2-way sync job with the folder on nas again, then windows client app would create a new local folder on PC. You can click the share icon with a 2-way sync job to access its local synced folder.
I didn't realize that it created a whole new directory (that was my issue, I kept looking where it always is/was), so this will be the new local directory (c:/users/username/comp_name (readyNAS)/dir/dir...) that I need to use/access. I should be all set, moving forward. I want to thank you for your time, help and and most of all your patience! I apprecaite it!
BingkeX
Mar 21, 2017NETGEAR Expert
Hi Brenakie772,
Would you please check what kind of sync jobs do you have?
If it is "sync with pc", the icon is 2-way sync jobs on the share icon. There it can upload local file/folder to nas share and download file/folder to local directory.
If it is "backup pc folders", the icon is one-way sync jobs on the share icon. There it just upload local file/folders to nas. File/folder changes on nas side cannot sync to local directory.
In your case, i guess your sync job is "backup pc folders" and one-way.
So if you want a 2-way job, you can select a share and create a "sync with pc" job for it.
Best Regards.
- Brenakie772Mar 22, 2017Tutor
Hi BingkeX,
Thanks for getting back to me. I think that's where the issue is. Where do I check these settings? I've looked on both the cloud and admin pages. Looked at the share, I'm not seeing anything re: sync under settings. Am I even in the right area???
Thanks,
B
- BingkeXMar 22, 2017NETGEAR Expert
Hi Brenakie772,
Please sign in readycloud Windows or Mac client app with readycloud users. Then check the sync job icons there.
The two-way sync job icon on share is
The one-way sync job icon on share is
If you want to create a two-way sync job, please click "sync menu" on right of a share, and then click "sync with PC".
If you want to create a one-way sync job, please click "Backup PC Folder" menu on bottom of each device.
Best Regards.
I'm a little embarassed, it was there right in front of me... Clicked now it's doing its thing, looks like it may take a bit.
you mentioned:
Are you still in the client app or in the readycloud site? The only menu to the right of a share is pause/stop backup.
THanks again, you've been most helpfull!!
B
