Brenakie772's avatar
Mar 21, 2017
ReadyCLOUD isn't Syncing
Hi,   Read some related threads and couldn't find a solution.   I have a PC directory on the readycloud and it's synced.   I was off site and needed to do some work.  I accessed the file (.PSD)...
  • Brenakie772's avatar
    Brenakie772
    Mar 24, 2017
    Do you see a green tick on share icon and "synchronized" status after sync is finished? Like sync_finished.png.
    Where do you check your local PC folders?
    YES!
    Notice: When you stop a one-way sync job, the original local folder on your PC don't have any connect with nas.  After you create a 2-way sync job with the folder on nas again, then windows client app would create a new local folder on PC. You can click the share icon with a 2-way sync job to access its local synced folder.
    I didn't realize that it created a whole new directory (that was my issue, I kept looking where it always is/was), so this will be the new local directory (c:/users/username/comp_name (readyNAS)/dir/dir...)  that I need to use/access.  I should be all set, moving forward. I want to thank you for your time, help and and most of all your patience!  I apprecaite it!
ProSupport for Business
