SmallTown
Mar 30, 2017Guide
ReadyCLOUD Login screwed up
I can't access my ReadyNAS files (won't let me sign in). My solution was to try to use the ReadyCloud (computer memorized my password) but it won't let me sign in either. I am beyond my 90 days so Ne...
Geronimo88
Mar 30, 2017Guide
Same here, this is an issue with ReadyCloud, I and many others are experiencing the same issues. Apparently the NetGear peeps are aware of a problem and working on it!
- SmallTownMar 30, 2017Guide
What is wrong with Netgear? Couldn't they have just told me that instead of saying "we won't talk to you unless you pay us"?
- Geronimo88Mar 30, 2017Guide
I know seems crazy, I have also messaged their Facebook page in hope of getting some more info. I have been trying to resolve this issue for about 5 hours, have got zero work done today, good job I had no clients in!!
Shouldn't I still be able to access it directly w/o going through their system though?
Yes you should If your plugged directly into it, Im still figuring out this myself.
- Dcurry508Mar 30, 2017Tutor
I am having this same issue you can log in throught the RAIDar Program in the admin page and this should allow you to access the files from there. I know it allows it for me. Hope this helps
Only admin page I used was through ReadyCLOUD. My question is why can't I log on to the ReadyNAS locally (within my network) even if ReadyCLOUD is down. I didn't get this so I would be dependent on an Internet service provider either. I got it LOCAL so I had it as a stand alone!!! If I go in through explorer, I can see the folders listed but have to log in to access them (but it won't take my login)
- CJDENMar 30, 2017Apprentice
oh yes
SmallTown wrote:Shouldn't I still be able to access it directly w/o going through their system though?
oh yes you can, but if it the same with you as with me, you will find that your data has been deleted. I had all my uploaded photos from my mobile devices deleted :-(
I you refering to data in your Home Folder?
- Oct 03, 2015Retired_Member
