SmallTown
Mar 30, 2017Guide
ReadyCLOUD Login screwed up
I can't access my ReadyNAS files (won't let me sign in). My solution was to try to use the ReadyCloud (computer memorized my password) but it won't let me sign in either. I am beyond my 90 days so Ne...
Geronimo88
Mar 30, 2017Guide
Same here, this is an issue with ReadyCloud, I and many others are experiencing the same issues. Apparently the NetGear peeps are aware of a problem and working on it!
SmallTown
Mar 30, 2017Guide
Shouldn't I still be able to access it directly w/o going through their system though?
- Geronimo88Mar 30, 2017Guide
Yes you should If your plugged directly into it, Im still figuring out this myself.
- Dcurry508Mar 30, 2017Tutor
I am having this same issue you can log in throught the RAIDar Program in the admin page and this should allow you to access the files from there. I know it allows it for me. Hope this helps
- SmallTownMar 30, 2017Guide
Only admin page I used was through ReadyCLOUD. My question is why can't I log on to the ReadyNAS locally (within my network) even if ReadyCLOUD is down. I didn't get this so I would be dependent on an Internet service provider either. I got it LOCAL so I had it as a stand alone!!! If I go in through explorer, I can see the folders listed but have to log in to access them (but it won't take my login)
- dwduvalMar 30, 2017Aspirant
If you go to Readycloud.netgear.com, hit the MANAGE button next to your device, you should be able to log is as Admin (if you know your admin password).
From there, I can still see everything that was backed up from every device. No data appears to have been deleted. All my users are deleted and can't access any other way though... huge problem.
But I can definitely confirm that no data has been deleted (at least on my system).
- CJDENMar 30, 2017Apprentice
oh yes
SmallTown wrote:Shouldn't I still be able to access it directly w/o going through their system though?
oh yes you can, but if it the same with you as with me, you will find that your data has been deleted. I had all my uploaded photos from my mobile devices deleted :-(
I you refering to data in your Home Folder?
Geronimo88 wrote:I you refering to data in your Home Folder?
Yep. The cloud user account has been deleted from the NAS as well as the data uploaded from mobile devices.
- Oct 03, 2015Retired_Member
