gianlucagin
May 27, 2016Aspirant
ReadyCloud login
HI.
I've just converted my readycloud account into mynetgear account.
I've updated NAS firmware and readycloud client but when i make login it says NAS is offline instead it's online.
Can you help me to solve?
- JennCNETGEAR Employee Retired
Hello gianlucagin,
Can you check again please if the FW is updated? Under Cloud, it should look different now. The ReadyCloud account login should now appear in an email address format.
Also, the ReadyCloud client you mentioned, is that a Windows desktop client? Make sure it is v 1.12 and the account you enter is in an email address format too.
- gianlucaginAspirant
Hello.
I've 6.5.0 FW in my NAS and v.1.12 Windows ReadyCloud client with an e-mail log-in but still it remains off-line.
If you give me your e-mail i send you a screenshoot.
Thks.
- JohnRoNETGEAR Employee Retired
Hi gianlucagin,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
- Oct 02, 2015Retired_Member
