jbuchal
May 26, 2020Tutor
ReadyCloud "no volume or usb disk" error message
I have been using ReadyCloud for a long time without problems. Now I cannot acces the NAS remotely, though it still works fine on the local network. I can sign in just fine, but can't see anything,...
- May 28, 2020
Hi all,
There was an issue in viewing the shared folders on the ReadyCLOUD web portal but this should be fixed now. Please check if you are now able to see the shared folders on the web portal.
luckyo
May 27, 2020Aspirant
I have the same problem.
Two readynas are being used and both have the same symptoms.
I can't find shared folders/files in web browser.
But, "ReadyCLOUD.If you run exe" and look at it, you'll read the file&folders normally.
I guess it's not a NAS configuration or firmware issue. I'd like to solution from Netgear.
JohnCM_S
May 28, 2020NETGEAR Employee Retired
Hi all,
