DavidCXX
Nov 26, 2015Aspirant
Readycloud not playing avi and mkv files, only MP4
Hello, I am using an iPad 2 and readycloud with readynas but it won't play avi or mkv files. Mp4 files work absolutely fine but avi files just the QuickTime Q logo appears, it looks like it is trying...
Nov 26, 2015Guru - Experienced User
I think your problem is because the ipad's built-in video player doesn't support avi or mkv - and readycloud uses that player.
What NAS do you own?
DavidCXX
Nov 27, 2015Aspirant
is there a way using readynas with another video player such as vlc? I have this and 8player - I would create a VPN instead as I have heard that is one approach, but I have no idea how to do this or if it is possible?
- StephenBNov 27, 2015Guru - Experienced User
There are two options that I think are worth trying next. Neither require ReadyCloud.
One is AVPlayerHD. It will play both AVI and MKV, and you can connect to it over the internet using FTP.
You could also try Plex. There is a free plex server app available for the RN104. The challenge here is that the RN104 isn't capable of real-time transcoding, which limits what you can play. Still, it is worth a try.
- DavidCXXNov 27, 2015Aspirant
Sorry yes I also had tried plex and had hit the transcoding issue - if I had known about that I would have bought a better NAS box! On that question is it difficult to upgrade to a better box in terms of all the stuff I have on the hard drives? Or can I just switch them over to a better one? If so any suggestions?
But re AVPlayerHD, I'll definitely try that thanks. I am really sorry to ask but what does that mean re FTP? Is there an easy (idiot's) guide to how I do this?
Many thanks for your help on this.
- StephenBNov 28, 2015Guru - Experienced User
As far as FTP goes, there are some guides here. AVplayerHD also supports smb, so you can check the playback of your files w/o FTP.
You can migrate to another OS6 NAS pretty easily. Uninstall the apps, move the disks (with the units powered down), then do an OS reinstall from the new unit. Then reinstall the apps.
I do recommend updating your backup first though.
