neilvranch
Oct 18, 2016Aspirant
ReadyCLOUD off line
Hello, I have two Readynas 104 - one is working great - the other is show greyed out button on just the readycloud which will not turn off or on, also is not show ticks above showning internet or ser...
Oct 18, 2016Guru - Experienced User
Do both use static addresses? If so, check the DNS servers configured for unconnected unit.
neilvranch
Thanks Stephen, both units area static ip, and both units are configured the same - I have tried 8.8.8.8 and 8.8.8.4 and the ip of the router for the DNS
- mdgm-ntgrOct 18, 2016NETGEAR Employee Retired
The secondary Google DNS server is 8.8.4.4 not 8.8.8.4.
Can you send in the logs from both devices (see the Sending Logs link in my sig)?
Please specify which is for the unit that is working fine and which isn't. - neilvranchOct 19, 2016Aspirant
it wouldnt let me send logs by reply but have emailed them.
is this correct
Thanks
Neil
