CHEN369
Feb 28, 2021Aspirant
ReadyCloud on a Redirect Loop
Hello Community, I'd like to report an issue that my users have been expirencing using the latest Google Chrome browsers. Version 88.0.4324.190 some users expirence in my team expirence this issu...
Marc_V
Mar 01, 2021NETGEAR Employee Retired
Welcome to the Community!
I have the same build of Chrome browser but also not experiencing any issues with it. Have you tried clearing browsing data on the workstations that are having issues accessing ReadyCloud?
Perhaps trying to reinstall the Chrome browser is another option if clearing the data will not help.
Also all your users are connecting to the same ISP right?
CHEN369
Mar 01, 2021Aspirant
Hey Marc_V
We've tried clearing cache and cookies. The issue still replicates even in Incognido.
The thing is wired, its feels like it keeps redirecting itself between HTTPS and HTTP but there might be some sort of script that keeps detecting HTTP and forcing a HTTPS page but then it redirects back to HTTP in an endless loop.
The same account can exhibit this behavior, theres got to be some sort of security setting that is being enabled on any new installations of Chrome and I cant figure out whats causing it.
We have two computers with the same Chrome version and one exhibits the behavior and one does not and also the same AD account and same Netgear account
However one PC (that does have this issue) was just installed chrome recently while the other PC has had Chrome installed for more than a few months.
This is a sporatic issue that some chrome browsers replicate and some do not.
- CHEN369Mar 01, 2021Aspirant
And Yes, we do use the same ISP..
We even went as far as using the Same Server (13.35.90.80)
Thinking that maybe theres a problem with a Server somewhere ..
that did not work unfortunatly.We tired diffrent ISPs and same thing..
Some Chrome browsers work some dont even if they are the same version- StephenBMar 02, 2021Guru - Experienced User
Another user also reported this, and found that reinstalling Chrome worked. https://community.netgear.com/t5/ReadyNAS-Cloud-Storage/ReadyCloud-not-loading-in-Google-Chrome/m-p/2058622
- CHEN369Mar 02, 2021AspirantThat may work but in my case, a brand new OS with a brand-new fresh install of chrome replicates this issue however the PC that was installed last year does not.
Thankfully it looks like we aren't the only people who have this issue.
I think there's an underlying issue with SSL and HTTP .. cause when it does work you are on netgear is on HTTP and not HTTPs .. it shouldn't be that way it should be HTTPS across-the-board but idk if Netgear has some sort of load balancing issue with their reverse proxys or something.
But then again it feels like chrome is enforcing https but netgear comes right back around and 301 redirects back to a http and the cycle continues..
