Blanker-2's avatar
Blanker-2
Apprentice
Oct 09, 2018
Readycloud practicality
I'm trying out readycloud and have been using it for a couple weeks now. I get that it's an easier way to access your Nas instead of configuring port settings on your router.
1. Is it always slow to connect?
2. When backing up pictures from your phone, it doesn't seem to do this in the background. do I need to manually launch the readycloud app to start this process every day?
3. I cannot see picture thumbnails on any of the pictures. I need to click on them to see what the picture is. This is kind of a deal-breaker for me.
I'm not sure I see the advantages here over Google drive or Google photos since the latter will do two and three. I get that readycloud is your own private cloud but that doesn't seem to be enough for me. Just wondering if I'm missing something here. thanks
  • Retired_Member's avatar
    Retired_Member
    Hello Blanker
    to get fast connection,you can connect your cell phone and NAS in the same network.
    you can enable "Backup in Background" in backup setting page.when this feature is enabled,ReadyCLOUD app will backup new photos automatically in background.
    are you using IOS app?I can see the thumbnails of JPG files.
    • Blanker-2's avatar
      Blanker-2
      Apprentice
      Thanks. I'm using the readycloud android app and i don't see #2 or 3
        Retired_Member
        Hi Blanker
        ReadyCLOUD dev will release Android app 2.0.0 this week,please verify issue 2&3 you mentioned in the new version.
ProSupport for Business
