Blanker-2
Oct 10, 2018Guide
Readycloud practicality
I'm trying out readycloud and have been using it for a couple weeks now. I get that it's an easier way to access your Nas instead of configuring port settings on your router. 1. Is it always slow t...
Retired_Member
Oct 10, 2018Hi Blanker
ReadyCLOUD dev will release Android app 2.0.0 this week,please verify issue 2&3 you mentioned in the new version.
Blanker-2
Oct 11, 2018Guide
I just updated the app. Thanks for that info! I can now see thumbnails. I wish there was a view option to see them in a grid similar to Google Drive rather than a column. The thumbnails are kind of small but I'm happy enough. I can't have everything I guess. For number two, I do not see an option that will allow backup in the background. perhaps it just does it automatically now? I'll keep an eye on it. Thank you very much
