OOM-9's avatar
OOM-9
NETGEAR Expert
Mar 05, 2019
ReadyCLOUD Security Update
ReadyCLOUD has gone through a security update this week. The security update will encounter connection issues if you are running a browser version that is over 12 years old and if you are using an older version of the ReadyCLOUD Desktop Clients.
All current versions of Chrome, IE, Safari, Firefox, Edge, etc... support the more current standards of security that is required with the ReadyCLOUD server.
The ReadyCLOUD Desktop Clients will encounter some connection issues that will require the newer version. There is an update option built into the app that will depend on this same connection method. The only way to get the update is by download:
Windows: http://readycloud.netgear.com/client/install/ReadyCloudSetup.exe
MacOS: http://readycloud.netgear.com/client/install/ReadyCLOUD.pkg
Note: Connection issues with the ReadyCLOUD Desktop Client may have a message similar to this:
"Network Error
ReadyCLOUD server is unavailable"
ProSupport for Business
