natepiet
Apr 28, 2014Aspirant
ReadyCLOUD Shares Displaying Red Lock
Hi Guys, I started setting up the ReadyCLOUD for my ReadyNAS (6.1.7) a few weeks back and I'm having some issues. I can successfully log into https://readycloud.netgear.com and see the 3 tabs a...
JefferyS
Aug 12, 2014Aspirant
Hi, I'm normally not one to bring up an old issue but I'm having this exact problem. All of my folders are locked.
Let's take the Music folder, I've reset the file permissions back to default as well as the owner and group to guest. Anonymous access is enabled. On ReadyCloud the permissions are set to everyone R/W.
I don't know what else to do but the red lock is still there. There on all the folders I've created but I'm using the Music folder as an example because it had the lowest possible setting for access you can get.
Anyone have any Ideas why I'm getting red locks on everything especially the Music folder which has full permissions for everyone and guest and anonymous access?
Thanks,
Jeffery
Thanks,
Jeffery
