natepiet
Apr 28, 2014Aspirant
ReadyCLOUD Shares Displaying Red Lock
Hi Guys, I started setting up the ReadyCLOUD for my ReadyNAS (6.1.7) a few weeks back and I'm having some issues. I can successfully log into https://readycloud.netgear.com and see the 3 tabs a...
mdgm-ntgr
Oct 08, 2014NETGEAR Employee Retired
Did you login using the same case for the username as you used when you registered? If not, can you try that? e.g.if when you registered you spelt the user as e.g. "mYNaMe" (no quotes) try spelling it the same way when logging in to ReadyCloud.
