natepiet
Apr 28, 2014Aspirant
ReadyCLOUD Shares Displaying Red Lock
Hi Guys, I started setting up the ReadyCLOUD for my ReadyNAS (6.1.7) a few weeks back and I'm having some issues. I can successfully log into https://readycloud.netgear.com and see the 3 tabs a...
davesumm
Oct 09, 2014Luminary
mdgm wrote: Did you login using the same case for the username as you used when you registered? If not, can you try that? e.g.if when you registered you spelt the user as e.g. "mYNaMe" (no quotes) try spelling it the same way when logging in to ReadyCloud.
HA! i tried it both ways and one way (Capitalised first letter) gave me the red padlock and the other way showed no padlock and works correctly. Why, oh why, does it make any difference?
Thanks for the tip!
