aleutian
Dec 01, 2015Follower
ReadyCloud Still down?
Obviously it is still not fixed, can't use the desktop app or the web portal, everything from don't see any volumes to just sitting there connecting for the last 3 hours. If tyhis nonsense continues ...
mdgm-ntgr
Dec 01, 2015NETGEAR Employee Retired
Hi aleutian,
The services are back up. Another user who though there was still an outage, found his problems were resolved after he updated to 6.4.1. Have you updated to 6.4.1 yet?
You can update to 6.4.1 via the local admin UI at http://ip.address.of.nas (one way to access this web page is to click setup in RAIDar)
Ramonlaar
Jan 04, 2016Aspirant
it seems that this problem still exists i have the same issue (6.4.1 indeed installed)
- BrianL2Jan 04, 2016NETGEAR Employee Retired
Hi Ramonlaar,
Can you provide some screenshots and error messages if any.
Kind regards.BrianL
NETGEAR Community Team- RamonlaarJan 06, 2016Aspirant
i dont get a message my icon stays gray and i can not right click to give my credentials
- BrianL2Jan 06, 2016NETGEAR Employee Retired
Hi Ramonlaar,
It seems that there's a problem with the app installed in your PC. Have you tried accessing your files through the ReadyCLOUD portal page or mobile app?
Kind regards,
BrianL
