gerryv
Aug 10, 2016Aspirant
ReadyCloud Stuck at Synchronizing 0%
Hi all, I am having an issue with the ReadyCloud app on my Windows 10 machine synchronising properly with my ReadyNAS 102 system. I have added a few folders, and whilst most appear to synchronise...
gerryv
Aug 11, 2016Aspirant
Hi Brian,
Yes, several times but to no avail. The first time the backup was initiated, one of two files in some of the subfolders were open. During subsequent attempts all files have been closed (I have attempted directly after rebooting the PC, so nothing has been open).
Thanks
BrianL2
Aug 11, 2016NETGEAR Employee Retired
Hi gerryv,
Thanks for your feedback. Have you check if the app is being blocked by your PCs firewall or AV software? Also, have you considered trying this on another PC to see if you will get the same behavior?
Kind regards,
BrianL
NETGEAR Community Team
- gerryvAug 12, 2016Aspirant
Hi Brian,
Yes, I have and that doesn't appear to be the issue as other PC folders sync without issue. Unfortunately I don't have another PC, just my laptop.
Can you tell me what the "service starting" log line actually refers to? Is there a way I can manually force the service to start?
Thanks
- BrianL2Aug 14, 2016NETGEAR Employee Retired
Hi gerryv,
That line or entry probably pertains to the event when the app or backup was launched. Could you send me the log or at lease a screenshot of it?
Kind regards,
BrianL
