TechTBI
Mar 01, 2021Initiate
ReadyCloud webpage don't load with Google Chrome
Hi there, Since a few days now, i can't access to the Readynas cloud webpage with Google Chrome. I disabled extensions, reset cookies and history, still the same : the webpage always reload and n...
JohnCM_S
Mar 03, 2021NETGEAR Employee Retired
Hi TechTBI,
Welcome to the Community!
You can try uninstalling then re-installing Google Chrome and see if you will be to access the ReadyCLOUD web portal after that. Some users who experienced the same issue were able to fix it after reinstalling Chrome.
- TechTBIMar 03, 2021Initiate
Thanks a lot for your reply, i'll try this and see if it works :-)
- NanodotMar 10, 2021Initiate
I simply switched to firefox for now.
Netgear putting the "onus" on me for this issue is not what i am looking for here as a "solution".
Chrome worked fine up until ~2 weeks ago. Clearly it is someting Chrome updated that Readcloud does not like.
