uffgnu14
May 18, 2016Luminary
ReadyCLOUD Windows client 1.12 not connecting over cellular network
ReadyNAS Ultra2 Plus RN OS 6.5.0 (New 18-May-2016) ReadyCLOUD 1.12.1259.456 for Windows (New 18-May-2016) Windows 10 Home Hi I'm unable to connect with ReadyCLOUD Windows client over cellu...
- Jun 13, 2016HiI just got the opportunity to test ReadyCLOUD windows desktop client over a remote
fixed-line internet connection. I got "Connected(VPN) within 1 1/2 minute and listed
shares could be accessed but no home shares could be seen.The RC Desktop client seems working (connection-wise) with local andremote (fixed and cellular) network.Regards,
Ulf
JennC
May 18, 2016NETGEAR Employee Retired
Hello uffgnu14,
You should be using the upgraded ReadyCloud account which is the same with myNetgear account, please check if you have done the migration to myNetgear account.
- uffgnu14May 18, 2016Luminary
Hi
Yes, I'm using same as myNetgear account.
Ulf
