uffgnu14
May 18, 2016Luminary
ReadyCLOUD Windows client 1.12 not connecting over cellular network
ReadyNAS Ultra2 Plus RN OS 6.5.0 (New 18-May-2016) ReadyCLOUD 1.12.1259.456 for Windows (New 18-May-2016) Windows 10 Home Hi I'm unable to connect with ReadyCLOUD Windows client over cellu...
- Jun 13, 2016HiI just got the opportunity to test ReadyCLOUD windows desktop client over a remote
fixed-line internet connection. I got "Connected(VPN) within 1 1/2 minute and listed
shares could be accessed but no home shares could be seen.The RC Desktop client seems working (connection-wise) with local andremote (fixed and cellular) network.Regards,
Ulf
RyeBread
May 19, 2016Tutor
Hello,
I'm having the Same thing here no WAN on PC
All it says is "online(VPN Disconnected)"
Thanks
Thanks
uffgnu14
May 19, 2016Luminary
Hi mdgm
Yes, working fine on my local network.
Unfortunate, I do not have access to a remote network in the near future.
Can also add that the Mobile client, version 1.2.3 for Android, is working fine on both local (WIFI) and cellular network.
Ulf
- mdgm-ntgrMay 20, 2016NETGEAR Employee Retired
That's unfortunate as testing on a remote fixed line connection is an important step in isolating the cause of this problem.
- uffgnu14Jun 09, 2016LuminaryHiBesides not beeing able to connect remotely with the ReadyCLOUD Desktop client, I found that when "Connected(Local)"
I don't see any home folders, neither "home", email-address folder or other home folders.
Shouldn't I see any of these when I'm Signed in with the RC admin-account?
With RC Portal I can see all home folders and with the RC Mobile client I can see my home folder.
Ulf- uffgnu14Jun 10, 2016LuminaryHiThis evening ReadyCLOUD Windows client suddenly connected remotely over cellular network
but it took over 3 minutes to get from "Connecting..." to "Connected(VPN)".
As mentioned in previous post I still can't see any home shares.
Ulf
