uffgnu14
Jun 21, 2016Luminary
ReadyCLOUD Windows client 1.12 not showing home folder
ReadyNAS Ultra2 Plus RN OS 6.5.0/6.5.1-RC1 ReadyCLOUD 1.12.1259.456 for Windows Windows 10 Home Hi I don't see any home folder, neither "home", email-address(MyNetgear-account) or other hom...
- Jul 07, 2016HiReadyCLOUD Windows client is working fine although I have to wait quite long until connected.Regrds,
Ulf
JennC
Jun 21, 2016NETGEAR Employee Retired
Hello uffgnu14,
When you click any of the shared folders this will open Windows explorer, can you see the home share when you go to root directory?
uffgnu14
Hi JennC
By first using a folder listed in ReadyCLOUD client I can get to
my home folder (MyNetgear mail-account) within Explorer.
Ulf
Ulf
- vjohnsonJun 21, 2016Aspirant
uffgnu14 wrote:Hi JennCBy first using a folder listed in ReadyCLOUD client I can get to
my home folder (MyNetgear mail-account) within Explorer.Regards,
UlfSo how do I sync my home folder using the ReadyCLOUD app if I can't see it? Yes I can get to it through file explorer, but what I want to do is sync my home folder. Please help.
- JennCJun 22, 2016NETGEAR Employee Retired
Hello vjohnson,
What you can sync with the computer is a shared folder. A new folder in the computer directory will be created following the name of the share that you synced with it. Whatever file you add to that folder will automatically be added to the ReadyNAS share that is set to sync with it.
Currently that is how the ReadyCloud app is designed.
Have you tried contacting support to ask about this home folder missing the ReadyCloud?
- JennCJun 25, 2016NETGEAR Employee Retired
Hello vjohnson,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accept as Solution” so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
