JohnnyB75
Aug 28, 2015Aspirant
ReadyDrop high CPU usage
Hi I've installed ReadyCloud on my Windows 10 32-bit Notebook which has an Intel Core2 Duo 2.26GHz CPU with 4Gb RAM and ReadyCloudClient app has spawn 4 ReadDrop instances and between the 5 app i...
JohnnyB75
Sep 08, 2015Aspirant
Hi
I agree that I would see a spike in CPU during the inital sync each day however this is constant high CPU usage. I'm guessing there is two reasons for this:
- That ReadyCloud app and ReadyDrop are constantly scanning the directories for changes
- Some of the directories it's trying to sync have over 100k files in them
The problem is that the content isn't changing much in the folders with a large number of files; maybe once a month for my pictures folder which includes my photo's, their thumbnails and my adobe lightroom catelog.
I'm currently looking at using a third-party app that allows my to schedule my backup intervals (on startup) and backup mechanism (copy if changed).
Any suggestion on how to use the ReadyCloud app to achieve a similar result would be greatly appreciated as I'm going to have to pay for the backup solution I'm currently evaluating soon.
Regards
John.
BrianL2
Sep 08, 2015NETGEAR Employee Retired
Hi JohnnyB75,
Can you tell us the Firmware version of your ReadyNAS and the version of the ReadyCLOUD desktop app installed in your PC?
Kind regards,
BrianL
NETGEAR Community
- JohnnyB75Sep 08, 2015Aspirant
The firmware version on my NAS is 6.2.5 and I've uninstalled the ReadyCloud app but it was the latest version of the Netgear website (I've only had the has less than a month now).
Regards
John.
- BrianL2Sep 08, 2015NETGEAR Employee Retired
Hi JohnnyB75,
I forgot to ask, what is the Operating System of your PC? If you are using Windows 10, please try this beta app.
Kind regards,
BrianL
NETGEAR Community- JohnnyB75Sep 08, 2015Aspirant
Hi,
Yes I am using Windows 10, I'll try out the beta and let you know how I go.
Regards
John.
