JohnnyB75
Aug 28, 2015Aspirant
ReadyDrop high CPU usage
Hi I've installed ReadyCloud on my Windows 10 32-bit Notebook which has an Intel Core2 Duo 2.26GHz CPU with 4Gb RAM and ReadyCloudClient app has spawn 4 ReadDrop instances and between the 5 app i...
JohnnyB75
Sep 19, 2015Aspirant
Still could get this version to work.
BrianL2
Sep 20, 2015NETGEAR Employee Retired
Hi JohnnyB75,
Can you try to re-install the said ReadyCLOUD Windows 10 beta desktop app software and set the Windows Compatibilty mode to Windows 7 or Windows 8. Also, can you confirm if you can still access your files through https://readycloud.netgear.com/ or other ReadyCLOUD app via mobile or PC.
Kind regards,
BrianL
NETGEAR Community Team
