bencan
Aug 24, 2018Aspirant
ReadyNAS 104 Internet Unavailable
Hello,
I just change internet service providers, ReadyCloud worked fine previously connected via Ethernet to the modem. Now connected to new wireless gateway and ISP by Ethernet I can log in ...
- Aug 25, 2018
Hi bencan,
You can try doing an OS reinstall. This will reset some settings on the NAS, such as Internet protocol settings and the administrator password, to default.
JohnCM_S
Aug 25, 2018NETGEAR Employee Retired
Hi bencan,
Welcome to the Community!
If a computer is connected to the wireless gateway via Ethernet, can it connect to the Internet?
- bencanAug 25, 2018Aspirant
Just tried a laptop and the internet does work from all 4 ethernet ports on the gateway. I swapped out the ethernet cable I used to test the laptop with the one I used for the Readynas just in case, but I have had green lights at the ethernet port on both the Readynas and the gateway from the beginning. With the new cable I tried discovery again without success and still says Internet Unavailable.
- JohnCM_SAug 25, 2018NETGEAR Employee Retired
Hi bencan,
I'm willing to try. I'm guessing no data losses will occur? And from the admin/settings, I would click 'Perform Factory Default'?
