bencan
Aug 24, 2018Aspirant
ReadyNAS 104 Internet Unavailable
Hello,
I just change internet service providers, ReadyCloud worked fine previously connected via Ethernet to the modem. Now connected to new wireless gateway and ISP by Ethernet I can log in ...
- Aug 25, 2018
Hi bencan,
You can try doing an OS reinstall. This will reset some settings on the NAS, such as Internet protocol settings and the administrator password, to default.
JohnCM_S
Aug 25, 2018NETGEAR Employee Retired
Hi bencan,
No, you need to select the OS reinstall option. This option will not delete the data on the NAS. You may check this link on how to access the boot menu and select the OS reinstall.
Aug 26, 2018Guru - Experienced User
but factory default will, so make sure you don't do that one.
- bencanAug 27, 2018Aspirant
It worked, internet available and ReadyCloud connected, thanks very much John!
