porkrind
Dec 30, 2019Aspirant
ReadyNAS 104 stuck in recovery loop
My ReadyNAS 104 was unplugged for a few days and now is stuck in "Booting from USB" mode - that mode automatically comes up when powered on. Without a recovery usb, it fails and cannot be turned off ...
- Dec 31, 2019
RAIDar doesn't even see it wiithout drives? That's a bad sign. I don't know if the USB recovery tests the files installed by it or not. If it doesn't, then it sounds like you still have a corrupt flash memory even with a "good" recovery, meaing the flash itself bad in some way.
Sandshark
Dec 30, 2019Sensei
The sequence you list with the USB is normal recovery, so the USB drive isn't the problem. It probably also means the OS is not the issue. What status does RAIDar report for the NAS?
Without drives, it should report "No Disks". If it reports something else, you likely have a hardware problem.
porkrind
Dec 31, 2019Aspirant
Thanks for the reply, Sandshark! RAIDar doesn't ever see the NAS because it's either in Boot from USB Failed state or in recovery mode followed by a shutdown. I cannot get the NAS to a steady "on" state.
I'll give it another couple of days to see if anyone else has insight. If not, I'll chalk it up to a hardware failure and accept your solution.
- SandsharkDec 31, 2019Sensei
- StephenBJan 01, 2020Guru - Experienced User
Sandshark wrote:
RAIDar doesn't even see it without drives? That's a bad sign.
I agree.
porkrind - the warranty for the RN100 series is three years for the original purchaser. If your NAS is still covered, you could get a warranty replacement via my.netgear.com.
- porkrindJan 01, 2020Aspirant
Yeah, it's stuck in a boot recovery loop and never actually reaches an operational state. I'm going to switch to data recovery, hoping the drives are still good.
The NAS was purchased in 2014 and has been working like a champ 24/7 for over 5 years. I'd hoped for longer, but I really can't complain. The tinkerer in me will probably open it up at some point to try to diagnose a potential hardware fix, but short-term focus is recovering a few days work since I didn't back up nightly.
Thanks for weighing in - I appreciate having confirmation of failure from more experienced folks.
