porkrind's avatar
porkrind
ReadyNAS 104 stuck in recovery loop
My ReadyNAS 104 was unplugged for a few days and now is stuck in "Booting from USB" mode - that mode automatically comes up when powered on. Without a recovery usb, it fails and cannot be turned off ...
  • Sandshark's avatar
    Sandshark
    Dec 31, 2019
    RAIDar doesn't even see it wiithout drives?  That's a bad sign.  I don't know if the USB recovery tests the files installed by it or not.  If it doesn't, then it sounds like you still have a corrupt flash memory even with a "good" recovery, meaing the flash itself bad in some way.
ProSupport for Business
