MJNAS
May 27, 2020Tutor
ReadyNAS 212 readycloud shares gone
Hi, hope someone can help. ReadyNAS 212, using latest firmware 6.10.3 All shares accessible OK on the LAN. Stopped working using readycloud - no shares visible to users even admin, except home fol...
- May 28, 2020
Hi all,
This issue with the ReadyCLOUD web portal should be resolved now. You may check if you can now see the shares on the web portal.
JohnCM_S
May 27, 2020NETGEAR Employee Retired
Hi MJNAS,
Welcome to the Community!
Is this when the users are viewing it on the ReadyCLOUD web portal?
If it is, our Engineering is already aware of this issue and they are working on fixing it. As a workaround, you can use the desktop app or mobile app to access shares they should not be affected by the issue.
SlyFox
May 28, 2020Aspirant
Have exactly the same issue on 6.10.3 with RN312.
Unfortunately, Android Mobile APP doesn't show shares as well (((
- IvanAlteyaMay 28, 2020Aspirant
I have the same issue with the RN424. I hope that the problems will be resolved as soon as possible!
