MJNAS
May 27, 2020Tutor
ReadyNAS 212 readycloud shares gone
Hi, hope someone can help. ReadyNAS 212, using latest firmware 6.10.3 All shares accessible OK on the LAN. Stopped working using readycloud - no shares visible to users even admin, except home fol...
- May 28, 2020
Hi all,
This issue with the ReadyCLOUD web portal should be resolved now. You may check if you can now see the shares on the web portal.
MJNAS
May 28, 2020Tutor
Hi, it's still not fixed - showing no volumesor usb disks, so no shared visible in the web portal. I can't grant access to shares because of this.
They don't show in the desktop or mobile app either.
This must be a major issue - is there anywhere i can check updates?
Thanks,
Jonathan
