patelshivrajs
May 07, 2025Aspirant
ReadyNAS 214 volume is inactive or dead.
I have been using RN214 from past 4 years. It has been working perfectly. Suddnely this morning we faced an immediate powerloss and after than when the RN214 started, we have been getting this er...
patelshivrajs
Hi Stephen! You are right. It is 4x2TB, this is what the quotation from my purchase says. But you rightly pointed out that the screenshot says only 3. There should be 4 disks.
I can send you the ZIP files of the logs that I have downloaded. I am somehow not being able to send you the PM. The envelope doesn't give me a drafting option, it opens up the inbox/sent only. Is there a possibility that you send me a PM and I can respond you with the link of ZIP file?
Please let me know, this would be of a great help!
May 07, 2025Guru - Experienced User
patelshivrajs said: Is there a possibility that you send me a PM and I can respond you with the link of ZIP file?
As I mentioned, PMs don't seem to be working with the new software. I've pointed this out to the forum admin - not sure how long it will take for Netgear to fix it.
