JVand
Jul 14, 2023Star
ReadyNAS 314 remote access
I'm attempting to set up a replacement for ReadyCloud using OpenVPN for accessing my files remotely. I've set up DDNS using noip.com and created a port forwarding rule in my router using TCP/UDP por...
- Jul 16, 2023
JVand wrote:
However, I'll still need to know what port the ReadyNAS uses for accessing files won't I?
No. You install the VPN client on your remote devices (phone and PC). When the VPN is connected, you'll have full access to your network (just as you would when you are home).
No need to forward SMB or other ports.
Jul 15, 2023Guru - Experienced User
JVand wrote:
I'm attempting to set up a replacement for ReadyCloud using OpenVPN for accessing my files remotely. I've set up DDNS using noip.com and created a port forwarding rule in my router using TCP/UDP port 6300.
Have you tried to install the OpenVPN server on the NAS? Generally it is much easier to get a router with built-in OpenVPN support.
It is possible to install ZeroTier on the NAS (and it doesn't need port forwarding). Not sure if it is possible to install the current version of OpenVPN on Debian Jessie.
JVand
Jul 16, 2023Star
Thanks for your reply StephenB I've decided to take your advice and purchase a router that supports OpenVPN. However, I'll still need to know what port the ReadyNAS uses for accessing files won't I? Is it 445 for SMB?
Thanks
- StephenBJul 16, 2023Guru - Experienced User
- JVandJul 16, 2023Star
Excellent. Thanks for your help.
