SAS1201
Jun 12, 2019Aspirant
Readynas Apache2 issues
I am having issues recently since I upgraded to 6.10.1. First of the images on the Admin web portal are not loading for the APPS that I have running. The next issue, is I have a few apps that are n...
WhoCares_
Jun 13, 2019Mentor
Hi Stephen,
Although I'm happy to see my add-ons used, the solution may be easier. What most likely happened here is that one or other add-on required PHP so it got installed from the official repo. Now I suspect that for some reason NTGR themselves forgot to build a new version of PHP5 that would work with Apache 2.4 as is shipping since 6.10.0 and include that version into the 6.10.x repos.
That said, there's also a chance that they actually built a new version but I don't think any packages already existing on the system would get upgraded on a firmware upgrade, essentially leading to the same problem. If NTGR did upgrade the PHP5 packages the solution to the problem would be as easy as
- logging into the NAS using SSH
- issuing "apt update && apt full-upgrade" and after that has finished
- "systemctl restart apache2"
-Stefan
SAS1201
Jun 13, 2019Aspirant
Thanks, when I try the apt update && apt full-upgrade as suggested and I am getting errors.. Any ideas?
Clearsigned file isn't valid, got 'NOSPLIT' (does the network require authentication?)
Fetched 15.7 kB in 2s (6,316 B/s)
Reading package lists... Done
E: Failed to fetch http://mirrors.kernel.org/debian/dists/jessie/InRelease Clearsigned file isn't valid, got 'NOSPLIT' (does the network require authentication?)
E: Failed to fetch http://security.debian.org/dists/jessie/updates/InRelease Clearsigned file isn't valid, got 'NOSPLIT' (does the network require authentication?)
E: Some index files failed to download. They have been ignored, or old ones used instead.
- WhoCares_Jun 13, 2019Mentor
Sounds like you're behind a proxy. What you can try is to tell apt to use that proxy by
- creating the file /etc/apt/apt.conf.d/00_proxy (using "vi /etc/apt/apt.conf.d/00_proxy")
- add the following lines:
Acquire::http::proxy "http://<proxy>"; Acquire::https::proxy "https://<proxy>"; Acquire::ftp::proxy "ftp://<proxy>"; Acquire::socks::proxy "socks:<proxy>";
(replace <proxy> with the actual location of the proxy you're using.
- save the file
- try the "apt update && apt full-upgrade" again
-Stefan
Smiley replacements in code blocks. Really, now?
-Stefan
- StephenBJun 13, 2019Guru - Experienced User
I've complained about it, and I think fixing it is on Lithium's "to do" list.
There is a fairly unobtrusive work-around which I applied to your post. That's to bold the :s that signal the emoticons
- SAS1201Jun 13, 2019Aspirant
Thanks for the help, I tried this and getting all different types of errors now.
Assuming the proxy is my firewall/GW - Private LAN IP address -
I am now getting this error..
E: Could not get lock /var/lib/apt/lists/lock - open (11: Resource temporarily unavailable)
E: Unable to lock directory /var/lib/apt/lists/- WhoCares_Jun 13, 2019Mentor
"All different types of errors" is a bit vague but the one you posted can be safely ignored. It normally means that the ReadyNAS itself was running the apt tool to check for "automatic updates". To make sure that no two processes write to the package database at the same time the apt tool will "lock" the file and that's (basically, it really is a bit more complicated than that) what the error message is telling you. If that happens just run your command again a minute later or so it should work then.
As for the firewall: that depends on whether the firewall actually has a proxy capability (most do) and of course on whether it is turned on. If it is that would mean you'd have to give your PC a proxy configuration for accessing the internet as well. That's what you'd have to enter for the <proxy> placeholder in my snippet above.
-Stefan
