morning912
Sep 10, 2020Aspirant
ReadyNAS Google Drive
I have just enabled the Google Drive sync on my ReadyNAS. Am I correct in thinking that the only option is for a continuous sync / mirror, rather than setting a schedule run? For example during the middle of the night everyday.
- Marc_VNETGEAR Employee Retired
Welcome to the Community!
You should be able to set interval settings on the Options tab under the Settings. This feature will affect how the NAS will check for any changes or updates on Google drive and the minimum interval is 30 seconds. However, you cannot set it to check by Time or Date you will have to compute in seconds.
HTH
- morning912Aspirant
Thanks Marc_V I see that feature, and will try it out.
The only thing is though, say I set the backup off today at 8am, and with an interval of 24 hours. It will run every morning at 8am.
The only way I can think of to get it to run at 2am, would be to manually run in that first time at 2am (which isn't feasible.) Is there another way?
