Mark_T_H
Mar 30, 2017Tutor
ReadyNAS is offline
I know this is an old issue, but out of the blue, our NAS is offline now after no one accessed it for a week. I tried rebooting the device and reinstalling the OS, but whether I log in through the d...
mdgm-ntgr
Mar 30, 2017NETGEAR Employee Retired
We've had a recent ReadyCLOUD outage.
Can you login to the local admin page as the 'admin' user (no quotes)?
Did you use home folders for your ReadyCLOUD users?
GeorgeBG
Mar 30, 2017Initiate
Hello,
Since yesterday i have the same issue. Turns out i can login through my home network as "admin", but my readycloud service says that my device is offline and all the other user can't login. My device is 202, OS 6.6.1
Thanks
- GeorgeBGMar 30, 2017Initiate
i just entered the settings and the readycloud was turned off. I enabled it again and it turns out okay. The problem is that all the contents of the home folders are not there! I cant see any of the stored contents that i have there?
- JackvdMar 31, 2017Apprentice
I have exactly the same problem.... But the worst thing is that ALL Readycloud users were deleted on two Readynas systems... It also triggered the removal of ALL data in the home-directories of the users.
Any chance that this gets high priority attention from development?
For me the event happened at 16:53 CET on March 30th.
Jack
- SilliMar 31, 2017Aspirant
I can't get into anything. I can see some folders but looks like home folders are gone. Not sure what to do now.
